Мультимедийный головные устройства штатного размера
hualingan "Хулиган"
HL-8710GB
Details
HOT SELLING
1,7.0 inch 16:9 Digital screen
2,V-6 disc changer memory
3,Light-Right Dual zone of front Amusement also call Dual zone-play. For example, the driver can listen to the radio by the speaker inside.While the passengers can enjoy TV or DVD by the wireless earphone
4,PICTURE IN PICTURE FUNCTION
5,OSD menu have five languages for choice:Espanol,Italian,Deutsch,Francais,English
6,steering wheel control
7,Bluetooth:BT-music,phonebook,call
8,Mucic:MP3,MP4,IPOD
9,TMC optional:Traffic Message Channel
10,Tire Pressure Monitoring System:compatible for those which with tire pressure monitoring function cars
11,SD card:store NAV software or multi-media document.support new type SDHC card,biggest 32GB
12,offer USB-HOST1.1 Jack,can read U disc,card reader
13,CAN BUS+air conditioner agreement
14,Compatible with DVD,VCD,CD,MP3,MPEG4,CD-R,WMA and JPEG playbacks
15,Built-in FM/AM Radio,RDS,movie,Time,calendar
Navigation Software equest
1,WinCE.net 6.0 CORE
2,Built in GPS--17 lanugages can be choose:English,German,French,Spanish
,Dutch,Hungarian,Czech,Danish,Norwegian,Swedish,Portuguese,Italian,Finland,Roumania,Greek,Russian,Poland
3,GPS dual zone function
4,Navigation PCB:COM2,Baud Rate:9600bps,The path of storageing SD Cards map:\Storagecard\*.exe;The path of storageing NandFlashs map :\NandFlash\*.exe.
5,support map:Igo 8,Route66,Gate5,Papago
In order to perfect your car's stereo effects, below accessories are be highly suggested:
1,2GB SD card which used to storage GPS map information.
2,TV antenna,in order to promote the TV clearly.
3,Monitor Reverse Radar,reverse car's Radar can show by alarm.
4,Headrest monitor,it's useful for the back people to watch DVD,TV,FM,and so on.
5,Infrared Headphones:listen to music matching headrest DVD
у дилеров пока таких нету :( , плюс не факт, что удастся подключить управление с руля.
Изменено пользователем qw29
Придется ждать несколько месяцев, пока не появятся фальшпанели, или колхозить, чего не хотелось бы.
Панель под навигацию очень похожа на двухдиновую.
В одном из установочных центров мне объявили вместе с изготовлением рамки установку Pioneera 2 din 34т.р.
Нехило. Рыло у них не потрескает?
они наверно имели ввду всю партию :lol:
Никак не могу найти рамку для мони, чтобы установить 2din мультимедиа!!!! Кто поможет??? :unsure:
только такая
Так это 1-диновая
другого пока не видел
Изменено пользователем grachik
А разве здесь не 2-din?
Похожа на 2 DIN, но это же навигация. Какой смысл заказывать машину с навигацией, чтобы ее потом выкинуть и поставить другую? Хотя, в контексте цены, запрошенной за установку Пионера (34 труб), это может оказаться даже выгодно :) .
На фото и есть пионер, о котором я писал, стоимостью почти 2Кб, это фот лежит недалеко от описания, а 34тр скорее всего только за установку :(
Мы с манагером как-то попытались вычислить цену ДВД навигации исходя из стоимости S-Max Thunder, в котором эта навигация стоит. Вычли из его цены все допы, на навигацию пришлось, по-моему 52000. СД-навигация будет стоить раза в полтора дешевле, примерно 35000. Пионер стоит в розницу 50000. 50000+35000=85000 (если делать самому, или +5-10 тр, если в ателье, при условии, что консоль 2 ДИН). Просто воткнуть Пионер вместо СД6000- 50000+34000=84000. В первом случае остается запасной девайс, который можно даже попытаться продать, во втором- только выкинуть, пока никто не видел (обратно его воткнуть можно будет только с помощью покупки новой панели).
Да я не к тому, что менять навигацию, просто если есть панель под навигацию, то её можно будет купить и туда влезет любое устройство 2-din. Думаю, панель будет стоить не шибко дорого:unsure:
Ну можно купить рамку окнтовки могнитолы которая рассчитана на штатную прямоугольную могнитолу
А уже тeда поставить обычную 2din
Форд сделал овальные магнитоллы и думает что тем самым защитил свои штатные магнитоллы от свалки!
Есть ли у кого какие предложения того как посмотреть водителю и пассажиру видео клип в Моне (не сломав шею заглядывая за подголовник)???
уже есть в продаже проставки только вот к сожаление под один дин 2 наврятли влезет поэтому как вариант одно диновая голова с выездным монитором
Проще сделать так, купить моник который крепится к торпеде и прикрепить его к месту где должна быть кнопка запуска, только со стороны пассажира, и кинуть в бардак ДВД проигрыватель. Естественно все сделать аккуратно и красиво, по-идее должно не плохо получиться.
А зачем такой геморрой-то разводить? если уж не трогать штатную систему, то дополнить можно портативным DVD, КПК, ноутбуком, кому что фанатзия позволяет. ИМХО портативный DVD будет удобней чем прибитый к торпеде, и места мало занимает и в выборе позиции для просмотра не ограничивает, хоть на пузо себе ставь (если пузо позволяет :) )
Я кстати договорился с дилером на установку семидюймовой навигации с DVD-проигрывателем, рамку сделают сами. Штатная уйдет в зачет стоимости. Будет готово - отпишусь.
