IPMB блок + передняя камера
6 часов назад, adyboss сказал:
Hello,
Sorry again for posting in English... but I'll be short:
Can anybody who installed front camera please send me the direct config (files) from APIM and IPMB (modified after installation)?
Thank you in advance.
Hey. Block configuration:
IPMB: DE00 - Front Camera Enable - Hardwire
APIM: DE01 - DAFVC Split View - Available
5 минут назад, adyboss сказал:
Thank you.
But I need the files (UCDS, direct config, save file).
Try to rule himself! Because in Russia there is no amplifier, and you probably have it and if you fill the configuration of our APIM, errors can pop up on the blocks!!!
I did it but I have a problem (described few post earlier).
I will not flash them. I only want to compare my config with a config which I know for sure is working.
28 минут назад, adyboss сказал:
Well, then you need to contact the author of the thread!!
19 минут назад, ZelDol сказал:
@adyboss I think the better way - is to find the car with factory installed IPMB and download direct config by VIN number from ETIS.
I have tried but... I am not sure is the correct way. Because an "original" HW config is a little bit different.
6 минут назад, Roman_Matveev сказал:
@adyboss And after the configuration change reset all modules does not help?
I did it. Unfortunately you saw (maybe) in the movie how it is.
Только что, Roman_Matveev сказал:
@adyboss Any bugs on the modules?
Not any error.
The single strange thing is that I don't see the calibration data for IPMA:
<m module="IPMA">
<d DID="F110" Desc="On-line Diagnostic Database Reference Number" Data="DS-FU5A-17E678-SC"/>
<d DID="F111" Desc="ECU Core Assembly Number" Data="FS7T-14G025-SE"/>
<d DID="F113" Desc="ECU Delivery Assembly Number" Data="FU5A-17E678-SE"/>
<d DID="F120" Desc="ECU Software #2 Part Number" Data="FT4T-14G082-MD"/>
<d DID="F124" Desc="ECU Calibration Data #1 Number" Data=""/>
<d DID="F125" Desc="ECU Calibration Data #2 Number" Data=""/>
<d DID="F162" Desc="Software Download Specification Version" Data=""/>
<d DID="F163" Desc="Diagnostic Specification Version" Data="0x03"/>
<d DID="F188" Desc="Vehicle Manufacturer ECU Software Number" Data="FS7T-14G019-SE"/>
</m>
  • 6 месяцев спустя...
День добрый. Есть желание на Ford Edge 2015 переднюю камеру воткнуть. В максимальной комплектации такая камера есть, но не могу даже примерно найти схему включения ее в SYNC 3. Насколько понимаю в sync 3 IPMB блок не нужен.
Но без схем догадку негде проверить. К тому же не ясно пока как forscan потом активировать переднюю камеру в ГУ.
Может кто подскажет где найти схему?
9 минут назад, 3DPrinter.UA сказал:
Это вряд ли. Скорее всего нужен. Схему у дилера спросить, дадут я думаю.
14 минут назад, ZelDol сказал:
А что дилеры уже бесплатно схемы дают?
11 минут назад, SadDarkAngel сказал:
Я слово бесплатно и не писал нигде :)
4 часа назад, ZelDol сказал:
https://www.drive2.ru/l/456829765106532773/ при наличии парка, ещё есть возможность что-то из этого выжать — там видеовход остаётся активным и при движении вперёд (нужно только разрулить переключение питания между камерами) тут есть инфа что видеовыход активен остается. как вариант как раз в него и подавать сигнал от передней камеры. зачем-то его оставили включенным
@3DPrinter.UA, на Sync2/3 можно в настройках включить задержку камеры. Тогда достаточно перекоммутировать видеосигнал с привязкой к фонарям заднего хода. Будет работать так: включаешь задний ход - включается задняя камера, переключаешься вперед - включается передняя камера (без нее продолжала бы показывать задняя). Отключение произойдет при достижении 10 км/ч. или при переключении передачи в паркинг. Я себе так сделал, теперь не представляю, как бы обходился без передней камеры.
6 часов назад, Alex_Erofeev сказал:
спасибо. а можно про это поподробней?
а можно как-то принудительно переключить на ближнюю?
Что произойдет если при движении видео сигнал с передней пропадет, а потом заново появится? не реагирует ли ГУ на появление видео сигнала на разъеме?
17 часов назад, 3DPrinter.UA сказал:
Да. Так и есть. На эксплорерах так и работает. Коммутируется питание между камерами.
10 часов назад, 3DPrinter.UA сказал:
Схему сделал примерно такую, но добавил вторую группу контактов реле, чтобы переключать оба провода от камеры. Если делал по схеме с коммутацией одного провода, то были перекрестные помехи.
В смысле - на переднюю? Сейчас активация и переключение происходят исключительно переводом рычага АКПП. Чтобы увидеть перед, надо сначала включить заднюю передачу, а потом переднюю. На мой взгляд этот маленький минус перекрывается простотой конструкции, сохранением штатных режимов и отсутствием необходимости каких-либо прошивок.
А почему сигнал должен пропасть при движении? Он пропадает только при переводе рычага в паркинг или при наборе скорости. А поскольку это штатный режим, то нет ни помех, ни реакции ГУ. Так же четко переключается перед/зад, полное ощущение родной системы.
Но повторю, главное условие - наличие в ГУ режима задержки отключения задней камеры.
Изменено пользователем Alex_Erofeev
Схема конечно простая и классная, но функционал выходит ограниченным. Например, подъезжая к парковке не получится увидеть что спереди. необходимо остановится, переключится на заднюю и только тогда продолжить паркование у бардюра. Было желание сделать включение камеры при срабатывание нештатного переднего парктроника, но реализация выйдет слишком накладной ;(
