adyboss
    Bucharest
    Ford Mondeo, B-Max
489 просмотров профиля
Достижения adyboss
  1. Gateway Module Please check the PDF file. Ford-Modules.pdf
  2. Solved with the help of @Roman_Matveev by flashing a new GWM FW. Thank you @Roman_Matveev and @SadDarkAngel!!! Parking Aid Camera.pdf
  3. I have tried but... I am not sure is the correct way. Because an "original" HW config is a little bit different. I did it. Unfortunately you saw (maybe) in the movie how it is. Not any error. The single strange thing is that I don't see the calibration data for IPMA: <m module="IPMA"> <d DID="F110" Desc="On-line Diagnostic Database Reference Number" Data="DS-FU5A-17E678-SC"/> <d DID="F111" Desc="ECU Core Assembly Number" Data="FS7T-14G025-SE"/> <d DID="F113" Desc="ECU Delivery Assembly Number" Data="FU5A-17E678-SE"/> <d DID="F120" Desc="ECU Software #2 Part Number" Data="FT4T-14G082-MD"/> <d DID="F124" Desc="ECU Calibration Data #1 Number" Data=""/> <d DID="F125" Desc="ECU Calibration Data #2 Number" Data=""/> <d DID="F162" Desc="Software Download Specification Version" Data=""/> <d DID="F163" Desc="Diagnostic Specification Version" Data="0x03"/> <d DID="F188" Desc="Vehicle Manufacturer ECU Software Number" Data="FS7T-14G019-SE"/> </m>
  4. So... There is only me and Grisha who installed the camera?
  5. I did it but I have a problem (described few post earlier). I will not flash them. I only want to compare my config with a config which I know for sure is working.
  6. Thank you. But I need the files (UCDS, direct config, save file).
  7. Hello, Sorry again for posting in English... but I'll be short: Can anybody who installed front camera please send me the direct config (files) from APIM and IPMB (modified after installation)? Thank you in advance.
  8. Hello, Sorry for posting in English and my apologies if this is not allowed but I'm doing it because is the last place where I can get help. With the big help of Grisha (all instructions and schemes) I was finally able to install the front camera. All good with the following problem: I can activate the front camera (from the Sound button but also with the wire direct to GND) only if first I look in reverse (R) and then move to N, D or S. You can see here: https://youtu.be/nv2XJ72rOZo I have connected at pin 40 in the connector C1035B... instead of DC/DC (I have low voltage converter DC/DC). Can be (or become) this a problem? I have checked the IPMA module details (I have no IPMB module in the module list!!) : <m module="IPMA"> <d DID="F110" Desc="On-line Diagnostic Database Reference Number" Data="DS-FU5A-17E678-SC"/> <d DID="F111" Desc="ECU Core Assembly Number" Data="FS7T-14G025-SE"/> <d DID="F113" Desc="ECU Delivery Assembly Number" Data="FU5A-17E678-SE"/> <d DID="F120" Desc="ECU Software #2 Part Number" Data="FT4T-14G082-MD"/> <d DID="F124" Desc="ECU Calibration Data #1 Number" Data=""/> <d DID="F125" Desc="ECU Calibration Data #2 Number" Data=""/> <d DID="F162" Desc="Software Download Specification Version" Data=""/> <d DID="F163" Desc="Diagnostic Specification Version" Data="0x03"/> <d DID="F188" Desc="Vehicle Manufacturer ECU Software Number" Data="FS7T-14G019-SE"/> </m> I don't know if this module is direct responsible with front camera (but as I have modified in IPMB the DE00 block, I was thinking of it) but I saw I have no value at ECU Calibration Data #1 and #2. Simulating an update to the IPMA module I saw that two other config files (approx 14 MB) should be downloaded. What I have now (SE): Update possible to SK: So, I am asking your help about how I can fix it because it definitely can work, as a lot of other improvements discovered by you are working Thank you in advance and sorry again for posting in English.
